watch cabinet for 60 watches
This cabinet will hold 60 watches in 4 drawers, 15 to each drawer and a drawer for watch parts. as much as i like working with cherry, walnut ect. i wanted this one to be different so its mostly butternut with walnut accents and inlay. DSCN1044.thumb.jpg.ad48ad50f5fde36de9a5ef770e7f413c.jpgDSCN1045.thumb.jpg.c6029a0850fd03986621da294b525702.jpgDSCN1046.thumb.jpg.3238c09ad7f26b990ba4dd7518768c95.jpgglued up four panels of butternut and one of walnut
dovetailed the walnut on both endsDSCN1047.thumb.jpg.cba36613d012824ec08b592b815255e9.jpgDSCN1048.thumb.jpg.7d291d441a813afa8f6ec0007abe7ce0.jpg
four pins and four tails then cut them off 2 1/2 inches wide
DSCN1049.thumb.jpg.8e083efe1dda296b67dd0867055fe12e.jpgDSCN1050.thumb.jpg.99d951e11d446b5f1e2fca2ca4c45903.jpg
if you're an idiot and drop one they break really easy, glue and clamps to the rescueDSCN1081.thumb.jpg.edf1c4976e9451605ed5d8437e3513e6.jpg
1/2 inch deep X 5/16 wide tongue and then some 1/8 inch inlay on the top and both sidesDSCN1083.thumb.jpg.303e7d76e1d4193f363c20a348996083.jpgDSCN1085.thumb.jpg.455bc5d1eafdd9143c07d2ee2ed0d882.jpg
view of the top and both side pieces done, next will be a groove in the walnut dovetailed pieces that will fit on the butternut, hopefully the next part will start to make some sense for you guys as to where i'm going with this, thanks for looking and as usual comments and questions are most welcome.
  • Replies 81
  • Views 20.2k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • This cabinet will hold 60 watches in 4 drawers, 15 to each drawer and a drawer for watch parts. as much as i like working with cherry, walnut ect. i wanted this one to be different so its mostly butte
  • finally got back in the shop!!!  these are test pieces for the inlay on the pulls, free hand 1/8" bit, too lazy to set up a guide router set up with half round bit and inlay installed b
  • OK, lets finish this journal up and call it done! this is a shot of the front with the door closed, after it was done i contemplated why i didn't put horizontal walnut on the top and bottom of th
Posted Images
Looks great! I used butternut on a project last year and really enjoyed working with it. Curious it appears your inlay template is raised above the work piece is that correct? If yes, can you explain the reason?
6 minutes ago, Eric. said:
.you have 60 watches?
not me E, i haven't worn a watch since i retired 15 years ago, its for a friend who has been collecting his whole life, all high end stuff, if there's room in the watch parts drawer i'm going to make a place for his collection of expensive pens.
Looks like a fun build!  Count me in to follow!
yep @pkinneb, when i made the templates i made them out of 1/4 inch scrap i had around and the guide would drag on the piece i was inlaying so i doubled them up, amateur mistake that i won't make again.
Good to know !
I love watches. I want to see this thing once it has the watches in it.
I've had a electronic gizmo of some sort in my pocket for the last 30 + years, all had a digital clock. Watches never survived long in my world, digital or wind up. But a cabinet to hold a collection of useless antiquities sounds quite interesting !
Butternut isn't available much around here. But the little I've worked with was some nice stuff.
Me too:)
its been a while since i've worked with it too Steve, its soft for a hardwood and tends to fuzz up when sanded, a little shellac and knock it down with some 320 does the trick, i just needed to work with something different this time. it is some pretty stuff and i see why they call it "white walnut".
12 minutes ago, treeslayer said:
Me too:)
I've had some killer watches. Not 60 though lol
Looking forward to seeing the progress and the finished piece all loaded up.  I was cleaning something the other day and found the 1 watch I own and haven't worn in 12 years.
glued the walnut and butternut pieces together yesterday, then a dry fit of the four pieces.DSCN1087.thumb.jpg.025bc1bad619640e384e1ab7f93552f8.jpg
router the back for the placement of the rear panel, probably ship lap or T&G in butternut.DSCN1089.thumb.jpg.3b5628ce873f8d8ab9d8f462198a3314.jpg
Looks great!!   How much trouble (since you already have the templates) would it be to continue the inlays through the Walnut edges, out of Butternut, that match the sweep of the mating parts?
Good question Tom and i initially thought of that and switch to butternut where it passes thru the walnut, double stick tape the pieces to the bench and careful layout as to where the inlay passed thru the dovetails maybe, i think there is a way for sure but i always planned on using a round-over router bit on the dovetails on the top of the case and the inlay would have to be very deep for it to continue from the top to the sides of the case. i rounded over the dovetails on a walnut hope chest i made for my daughter and liked the effect so thats the plan for this project.
24 minutes ago, RichardA said:
That's gonna be slicker than a Christmas ribbon.
Thanks Rick, i wanted this to be not like anything i have done in the past and build something a little out of my comfort zone, to be honest i go back and forth at this point as to whether i like it or not, it is different and thats what i was going for, i'll see how i feel tomorrow when i put some finish on it.
A combo of being out of town and without an iPad, I've missed this one. Looking good Dave! Neat combination of woods. Will you be attaching the drawer runners prior to glue up or after?
thanks Ken, full extension drawer slides on this one Coop per my friends request. i was going to make full extension wood dovetail slides but i'm glad he wanted ball bearing instead, wood would have been a lot more work. working on the drawers today, should have some more pictures tonight.
 threw together a box joint jig for the drawers, and the result. not too bad for a piece of junk dado set.DSCN1091.thumb.jpg.ddd6d1f0128457d135ea2695ababccc0.jpgDSCN1092.thumb.jpg.535d5f0c25afee854f35293a2678595d.jpg
parts for the dividers, made with the same jig, and i'm pleased with the fitDSCN1093.thumb.jpg.a7fb5425b39b4a76fd48c1b94157f80f.jpgDSCN1093.thumb.jpg.a7fb5425b39b4a76fd48c1b94157f80f.jpgDSCN1094.thumb.jpg.9abe0867c3a5455e9aaafd9d8dcab5b2.jpg
dry fit the pieces and got on a coat of shellac DSCN1096.thumb.jpg.9f49cde7816043aa6e352a2871046bb8.jpg
main case with two coats of ARS satin, i like the way the color came out, i'm starting to like this piece again. i'll glue the drawers and dividers together tomorrow and hopefully get some finish on them, thanks for looking guys.DSCN1097.thumb.jpg.5218111b811f5f3a7caf8a485ccd8605.jpgDSCN1100.thumb.jpg.0c11c0554b75df827fe4f40e978ec112.jpg
  • 26,009 Total Members
  • Joseph b Newest Member ·
