Valleyslim Posted February 1, 2019 Report Posted February 1, 2019 like the title says, im slowly trying to turn my side of a 2 car garage into a workshop,(i am a beginner) and a router would be a good addition to what little i have. I have narrowed it down to 2 routers with plunge and fixed base options here they are 1 https://www.amazon.com/dp/B00005RHPD/ref=psdc_552866_t1_B0000DCBKN 2 https://www.amazon.com/PORTER-CABLE-895PK-4-Horsepower-Fixed-Plunge/dp/B0000DCBKN/ref=as_li_ss_tl?ie=UTF8&qid=1533939426&sr=8-6&keywords=porter+cable+router&linkCode=sl1&tag=stumpynubs-20&linkId=21cebb518ff5864b0f532414a59f080e&language=en_US to be honest i think either 1 would be a great first router, just wanted to get your guys opinions, thanks Quote
wtnhighlander Posted February 1, 2019 Report Posted February 1, 2019 Hard to say, as neither of those links worked for me. The Porter Cable brand has a good reputation. A word of warning - routers tend to multiply, like marking gauges and try squares. One is never enough! 2 Quote
Popular Post gee-dub Posted February 1, 2019 Popular Post Report Posted February 1, 2019 Link also fail for me but, there is a standard answer. 15 years ago it was "for your first router, get a plunge". Now that there are so many good combo kits around I will modify this "for your first router, get a fixed/plunge base combo. Most of these are the 2-1/4 HP tier tools. Mine are all Milwaukee but, I got them years ago and unfortunately at this point in history, one cannot be confident of the quality of a given model unless recently purchased. The quality and favorites seem to be a moving target. I tried a DeWalt kit and returned it (a dozen years ago or so) due to quality issues but, see much praise for them now. The Bosch kits have a good following and of course, my favorite, Milwaukee has a solid camp as well. Part of what makes the Milwaukee work for me is the quality build, smooth plunge, great chuck and the fact that motors and bases are interchangeable for the 5615 and 5616. I use the fixed speed 5615's in various bases for tasks that favor that motor. I just swap to a 5616 motor if I want the variable speed and more power. Speaking of variable speed; it is critical to me and of no concern to others. Confusin' ain't it? As mentioned, routers multiply so this will likely not be your last. They are a hand tool and one's favorite is often due to the feel of the tool in the hands. A tippy router is a pain in the rear. One that you feel confident in guiding will be better for you. Try to get a few in your hands at the local tool place and don't be shy about handling them, plunging, them and taking the motor in and out (another super easy feature on the Mils). Here's some of mine in different bases for different reasons. 4 Quote
Tom King Posted February 1, 2019 Report Posted February 1, 2019 I have at least one of each kind, and brand, and multiples of some. When I need to change the bit in one, the first to get reached for is a newer Milwaukee. I don't remember the model number, but get one of the middle sized ones to start with. Quote
Mick S Posted February 1, 2019 Report Posted February 1, 2019 Here are the links the OP posted. 1. Bosch 1617 EVSPK 2. Porter Cable 895PK Both are good packages, and I agree that you should opt for a plunge base/fixed base option. Another thing to consider is the accessories that you'll eventually need for this and other routers. Things like guide bushings are not necessarily standardized, though Porter Cables bushing size is used on many brands - Bosch being one exception. You'll have to either use their bushings or get an adapter to use PC size bushings. Guide fences are another thing to consider, ease of table mounting, etc. As important as anything is how the router feels in your hands - the grips, switch location, balance, etc. Some plunge routers allow you to plunge after pushing down on a lever, some when you pull up on a lever. Some lock with a spring, others don't. Try to get your hands on several and get a feel for them. 2 Quote
fcschoenthal Posted February 1, 2019 Report Posted February 1, 2019 I have two of the PC 895 sets. One thing I love about the fixed base in a router table is the micro adjust through the table function. While both have variable speeds, the PC is also soft start. The PC also has dust collection on the plunge base. Chris "It's never too late to have a happy childhood" Quote
Chestnut Posted February 1, 2019 Report Posted February 1, 2019 I have 2 of the 890 sets as well and think they are a solid choice the plunge base has good DC. The plunge action isn't very smooth but it's improved if you add some dry lube to the guides. Honestly you can't go wrong with any of the big names. Dewalt, Porter cable, Makita, bosch, ect all make a good router. The best selling point to the Portercable router is i think their edge guide is one of the best. Quote
BillyJack Posted February 3, 2019 Report Posted February 3, 2019 Personally I would go with the bosch pk or the 693pk. I've got a couple PC 895's at work and not really thrilled with them.... Quote
Ron Swanson Jr. Posted February 7, 2019 Report Posted February 7, 2019 Both the routers you have listed are excellent choices. Here are a few things to keep in mind: 1. Porter Cable has easily the most aftermarket accessories available. 2. If you go with the Bosch, know that in order to use the PC style rub collars, you will need this: https://www.rockler.com/bosch-ra1129-quick-change-template-guide-adapter-kit - or you can buy that item with a number of Bosch rub collars. 3. The Bosch 1617 EVS kit has been replaced in the Bosch line with the far spendier MRC23EVSK. I have not had any experience using this new one, but I don't see enough changes in it to warrant the uptick in price, but maybe there are features I am not aware of. The power is virtually the same. This also means that you can usually get the 1617 EVS pk for a great price as stores sell off their existing inventory. I have the 1617 EVS pk and I really like it. Quote
legenddc Posted February 7, 2019 Report Posted February 7, 2019 53 minutes ago, applejackson said: 3. The Bosch 1617 EVS kit has been replaced in the Bosch line with the far spendier MRC23EVSK. I have not had any experience using this new one, but I don't see enough changes in it to warrant the uptick in price, but maybe there are features I am not aware of. The power is virtually the same. This also means that you can usually get the 1617 EVS pk for a great price as stores sell off their existing inventory. I have the 1617 EVS pk and I really like it. FYI - the MRC23EVSK has been out for over 10 years according to Amazon so the 1617 isn't going away anytime soon. The 1617 EVS kit goes on sale for either 179 or 189 fairly often. Quote
Chet Posted February 7, 2019 Report Posted February 7, 2019 35 minutes ago, legenddc said: Bosch line with the far spendier MRC23EVSK I was just watching a review of this model and it has a couple of features that to me makes it worth the price. One - the power switch is on the grip now so you don't have to start one handed. Two - it has a micro adjust on the plunge and fixed base. That, to me would be a real nice feature. Quote
Ron Swanson Jr. Posted February 7, 2019 Report Posted February 7, 2019 2 hours ago, legenddc said: FYI - the MRC23EVSK has been out for over 10 years according to Amazon so the 1617 isn't going away anytime soon. The 1617 EVS kit goes on sale for either 179 or 189 fairly often. I believe it first hit the market in 2010 in very limited supply. All I know is what I am told at the store I work at that sells both packages and t hat was is what I was told - that it's the replacement for the 1617 EVSpk. Quote
Robert Morse Posted February 14, 2019 Report Posted February 14, 2019 I have 2 sets of the Bosch 1617 (each with fixed and plunge bases). I love how smoothly they start up, and the wood handles on the fixed bases feel really nice in my hand. I also have a PC 690 fixed base and while very functional, it's not the one I reach for most of the time, due to how jerky it starts up - there's noticeable torque, while the Bosch routers spin up without the torque. Quote
Chip Sawdust Posted February 14, 2019 Report Posted February 14, 2019 I bought the Bosch 1617 as my second router (thus the "multiples" comment is valid for me) and it resides mostly in my Bosch router table. The first was the Dewalt PK611 router/plunger combo, which works fine for most hand held jobs. It's only got a 1/4" collet, and the Bosch comes with 1/4 and 1/2" collects, making it quite flexible depending on the job. I second (third?) the plunger/combo kit, as you'll want those. Add to that some nice guides to go along, and maybe a vacuum hose adaptor. I wish I had the plunger base for the 1617, which is about $99 when you buy it by itself. Then there's the bit collection. You may want to buy a "set" of "standard" bits, but although I've done that, I'd advise against it in retrospect. Get what you're going to need for the project at hand and you'll get good quality bits at a collection rate that fits your budget (your budget will grow!). Whiteside, Freud and yes, even Yonico make decent bits, but I lean towards those first two for my stuff. Oh my very first router was a Craftsman back in the late 70s and it still works but is quite basic. It'll spin a bit though Quote
Valleyslim Posted February 24, 2019 Author Report Posted February 24, 2019 So i think im gonna save up and buy the milwaukee plunge/base set, but i want to start off with a trim router for now just for edging mdf 1/2 and 3/4 inch. Is the 1hp colt bosch a good choice for that? a couple other choices are either rigid or makita all for 99, but the bosch is on sale at lowes for 89, the rigid is tempting as it comes with as a box sander for 99$ but i dont think i would ever use a box sander as i already have a random orbiting sander, thanks for all your good input Quote
wtnhighlander Posted February 25, 2019 Report Posted February 25, 2019 Any of those are pretty good choices. I suggest you investigate the accessories available for each, and let that influence your choice. A good edge guide is a very useful accessory. Some have dust collection add-ons that are very helpful, too. Quote
Bankstick Posted February 25, 2019 Report Posted February 25, 2019 If I was buying a new router, I would go with Mick's #1 suggestion- Bosch router pack. Quote
pkinneb Posted February 25, 2019 Report Posted February 25, 2019 Vallyslim I have all of those trim routers the Bosch is solid (i have 3) but the light on the Rigid is nice as well. If you watch CL you can pick palm routers up for $50 all the time I actually have several that I just keep bits in. 1 Quote
