about chisels, if i have 1/4" 1/2" & 1", are 3/8" & 3/4" needed? and for what 2" is used - is it worth it to get it a premium one or it's rarely used .. and with respect to dado's or grooves, what is the most common width in cabinet joinery
There is going to be a bunch of answers for these two questions.  What it boils down to, is what you need in your work flow. I have a bunch of tools that don't get used on every construct, but I'm glad I have them when I need them .   The most common dado width used is the one you need at the moment..
I work mostly with power tools, but use hand tools to refine/clean-up what the power tools have done and, sometimes, to do jobs my power tools can't do.  I don't own any "premium" chisels - my basic set are 21st century-vintage Stanley Sweetheart bench chisels - 1/4, 1/2, 3/4 and 1".  For what I do, I'm not sure premium chisels make sense - I have the idea that they are for folks who use their chisels all day, every day.
I have added, as needed, some individual chisels - mostly Narex.  There is a 3/8" mortising chisel, a 1/2" dovetail chisel, and 1/4" and 1" cranked neck chisels.  For my work, I've never seen a need for a chisel wider than 1".
Regarding dadoes - I work mostly with 3/4" stock (hence, the 3/8" mortising chisel), so 3/4" dadoes are common.  In drawers, I usually use 1/4" plywood bottoms, so 1/4" dadoes are also common.
As @RichardA said, what you need depends on what work you do.
Ding, ding, ding.  Agreed.  Like router bits, there are a few basic chisels and then dozens of "other" chisels.
My best advice is to use what you have and when you reach a point in a project where you need something different buy it. I have spent $$$$ buying tools that don't get used now I buy a tool when I need it.
I have too many sizes that I have collected over the years, but when I replaced my everyday chisels with premium chisels, I got 1/8, 1/4, 3/8, 1/2, 3/4 and 1 inch chisels. I use the 1/4 and 3/8's on dovetails, the 1/2, and 3/4 for general paring and the 1 inch for flushing things to the surface. I probably use my 1/2" more than any other. The 1/8" chisel is for nitpicky cleanup tasks. These chisels handle 90% of my woodworking tasks. the
On top of those, I have a couple of skew chisels, a couple of Japanese chisels for fine dovetailing, a fishtail chisel, a set of mortice chisels.... Having Tool Acquisition Syndrome does not make this an easy write....
Hi, I'm Robby and I am a tool addict
It doesn't help that Lie-Nielsen has there tool event less than two miles from house every February.
I have actually started giving some away to friends that are starting out on their woodworking journey.
I have two sets of the same 4 chisels, both a local tool sellers version.  I keep one in the shop and one in the basement where I tend to do some work when it's too cold.  They have .25 .5 .75 and 1" in the set and I haven't really found I need anything else.
There are two basic rules of operation for a chisel you need.  The one you need is the one you don't have, or you have so many that you know you have one that size, but can't find it.  I have two toolboxes full of chisels.  Chisel 1 has at least 6 rolls of chisels in it.
  • Haha 1
100% true.  The ancillary rule is that if you find the one you need, it'll be the one your wife, girlfriend, neighbor or other fiend used to open a paint can thus needing a total resharpening. (And, no, I did not misspell "friend.")
In a real low-budget situation, I'd start with a 1/4 or metric equivalent "bench" chisel. You can always make a bigger hole with a smaller chisel, but it doesn't work the other way around. I prefer longer irons, because I tend to pare more than pound.
Second, I would invest in a quality 3/8 mortising chisel. Quality, because you WILL pound the crap out of it. MY Robert Sorby was a bit pricey, but it takes a beating and retains an edge like you wouldn't believe.
Last, a 1" chisel, this one really is for paring, so long iron, or even a crank-neck, is worth considering.
Also, keep in mind that seldom-used sizes can be made from old chisels that are a bit wider. A bench top belt sander is great for taking material off the sides without overheating too quickly. Hit the flea markets and garage sales for beaters that you can customize.
I bought the Narex set, up to 2", and find that it makes life much easier.  I'm lazy/bad about sharpening, so I find that having a whole bunch of sharp chisels, which a full set allows me to have,  lets me keep working.  When I run out of sharp ones, then I can dedicate a hour or so to sharpening the whole set. I have also found the big ones (1 1/2" and 2") to be surprising useful for paring.
Overall, Narex is reasonably affordable and I don't every see myself buying a really premium set, and it really helps my workflow.  Having said that, I have certainly found myself in situations where I would have liked to have some of the more specialized chisesl (mortise, fishtail, etc), so I'll likely start buying those individually as needed.
what can you par with wide chisels?
25 minutes ago, walidantar said:
meaning is like sir, it's not my language so often i get in words that gets misunderstood
He ain’t bitching, it’s just the nicest thing anyone has ever said to him:D! You’re good!
  • Haha 1
  • Who's Online   1 Member, 0 Anonymous, 27 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
