Shane Jimerfield Posted April 9, 2015 Report Posted April 9, 2015 Wood zine tip of the day says, bottom of tooth should never be above the surface. I always have mine about 1/4" above. It's what I was taught back in the day. I usually get darn clean cuts, even cross cutting ply. What is your thought/experience on this?http://tips.woodmagazine.com/saws/set-the-right-height/ Quote
Woodenskye Posted April 9, 2015 Report Posted April 9, 2015 I set the blade to the bottom of the gullet but then again I could be wrong in my approach. Quote
davewyo Posted April 9, 2015 Report Posted April 9, 2015 Great question! I'll be interested in hearing what others do. I've heard everything from the bottom of the gullet to just getting through the work piece. I usually put mine ~ 1/8" (say half the saw tooth). I figure the more you raise the blade the more "flutter", deflection, or whatever it's called. I use a portable jobsite saw so (I imagine) deflection is an issue. D Quote
Coop Posted April 9, 2015 Report Posted April 9, 2015 I've heard that but it seems that if it's that low, it has more of a tenendcy to want to push the wood back. Instead of cutting down on the piece, it's cutting toward you. Quote
wdwerker Posted April 9, 2015 Report Posted April 9, 2015 Testing that on your saw and blades is a good idea. Sometimes I will have a blade much higher to improve the cut at the back of a crosscut. Full tooth clearing the wood was what I was taught, but that was a long time ago, always learning new approaches ! Quote
wtnhighlander Posted April 9, 2015 Report Posted April 9, 2015 I usually keep it as low as possible, just to minimize hot dog exposure. 2 Quote
PlaneAndDestroy Posted April 9, 2015 Report Posted April 9, 2015 That might be "best" for a rip, but to get the best surface finish without tearout the highest blade possible is best on a crosscut. The teeth plunge into the stock instead of tearing it sideways. It may not be safest, but it finishes the best. 1 Quote
Trip Posted April 9, 2015 Report Posted April 9, 2015 Two ‘old timer’ answers from patternmakers that I respect: First: tooth should extend fully above the surface at highest point of arc, but no more... Second: never expose more blade than the amount of flesh you can afford to lose… Take your pick.... 1 Quote
wdwerker Posted April 9, 2015 Report Posted April 9, 2015 Sounds like we have an answer ! 1/8 or so above it is ! Quote
Brendon_t Posted April 9, 2015 Report Posted April 9, 2015 I don't think I have ever looked at the position of the back tooth. I normally run about to the gullet for rips and I'll raise the blade about 5/8 out of the piece on cross cuts. Quote
knotscott Posted April 9, 2015 Report Posted April 9, 2015 That's really kind of a variable depending on the cut and the blade. There are pros and cons with every combination of blade and blade height, and there's no one-size fits all scenario. Let's say you happen to have a 60T 10" blade in the saw that was perfect for some 6/4" crosscuts in oak. You need to make one rip in the same material, but don't want to change out your blade. 60 teeth is generally high for a rip of this thickness, and has a fairly high chance of causing some burning....raising the blade higher than normal will reduce the length of time that the teeth contact the wood, thereby reducing the chance of burning. If you happen to have a 24T blade in place for the same task, which should inherently be less prone to burning, leaving the blade height lower will help give a smoother cut. Quote
TerryMcK Posted April 9, 2015 Report Posted April 9, 2015 Are we talking about the tooth at top dead centre here? If so I try to keep that one so the bottom of the gullet is just slightly shy of the top of the stock to be cut. Quote
dwacker Posted April 9, 2015 Report Posted April 9, 2015 I don't subscribe to any particular height. When I worked at the plant years ago all our saws were set and max cut height and had sign that said "don't touch". One L&I inspector will tell you keep it low another will tell you keep it an inch above, either way there is no written rule because the one written rule that actually exist makes blade height irrelevant. Use the blade guard, if yours sucks use a different guard. That said I just raise the blade up until I get tired of cranking the wheel which is usually close to 3". Quote
Llama Posted April 9, 2015 Report Posted April 9, 2015 I think this is the video where a guy from Forrest talks about this. I watched it a while back, seemed to have good info. Quote
PeteJr Posted April 9, 2015 Report Posted April 9, 2015 I raise the blade approximately 1/2" above the wood surface and I always use a blade guard. The Shark Guard with the 4" dust port works very well for my saw. My rule of thumb is to never place my fingers within 5" of a spinning blade. If that's not possible I use a push stick, safety device like the grr-ripper or a shop made jig. Quote
dwacker Posted April 9, 2015 Report Posted April 9, 2015 I think the low blade height is a liability thing rather than cut quality or blade life. There may be some sort of fear that the magazines would be considered professional / educational so there is liability. Personally I don't care about the safety aspect because I tend to agree with the idea that you should be using a guard. Ive been in a whole bunch of high production shops over the years and have never seen one that would agree with a low blade height but the all have one thing in common, a guard. 1 Quote
Trip Posted April 9, 2015 Report Posted April 9, 2015 Hi. I’m Ron from Forrest Manufacturing and I don’t use no stinking blade guards… Hi. Ron... BTW: In deference to Ron, I was also taught the 'pinky/thumb technique'... However, I was told to hook your pinky so you'd only lose your thumb... Just another viewpoint... 1 Quote
Trip Posted April 9, 2015 Report Posted April 9, 2015 So I don’t get any more emails… Pinky/thumb: Ron mentions it during the video… The pinky/thumb is an old-school technique summarized as, “Use your pinky so you don’t lose your thumb”… In the heyday of pattern making (before splitters, riving knives, etc), fences were both shorter and thinner… During a rip, you hooked your pinky over the fence so if stock got wonky, you could maintain leverage with the right side of your hand… Quote
Bombarde16 Posted April 9, 2015 Report Posted April 9, 2015 I picked it up somewhere along the way that the bottom of the gullet needs to clear the top of the cut. It works, and I haven't given it any more thought than that since then. Quote
Coastyboy Posted April 9, 2015 Report Posted April 9, 2015 I've had my own cabinet shop for years, worked at cabinet shops and custom wood stair shops and ALL removed guards once the insurance companies left, might not be good safety practice but it was done, guards get in the way much of the time. Quote
PlaneAndDestroy Posted April 9, 2015 Report Posted April 9, 2015 The reality is no one setting will be "best" for all aspects of a cutting system... Tearout, safety, dust collection, etc etc. You gotta find the compromise that works for you. Quote
ColinF Posted April 10, 2015 Report Posted April 10, 2015 So I don’t get any more emails… Pinky/thumb: Ron mentions it during the video… The pinky/thumb is an old-school technique summarized as, “Use your pinky so you don’t lose your thumb”… In the heyday of pattern making (before splitters, riving knives, etc), fences were both shorter and thinner… During a rip, you hooked your pinky over the fence so if stock got wonky, you could maintain leverage with the right side of your hand…I was taught this method and my shop teacher said it doesn't matter how high or low it is, if the board isn't kicking back and you cut a finger off it will be a life long reminder to use your brain! He was a bit of a grouchy old man Quote
weithman5 Posted April 10, 2015 Report Posted April 10, 2015 I keep the top of the workpiece between the blade tip and gullet bottom Quote
dwacker Posted April 10, 2015 Report Posted April 10, 2015 So I don’t get any more emails… Pinky/thumb: Ron mentions it during the video… The pinky/thumb is an old-school technique summarized as, “Use your pinky so you don’t lose your thumb”… In the heyday of pattern making (before splitters, riving knives, etc), fences were both shorter and thinner… During a rip, you hooked your pinky over the fence so if stock got wonky, you could maintain leverage with the right side of your hand… I have left my legacy with my method of using a tablesaw. Its now taught in all of our vocational programs in all three possibly more voc schools and at least three high schools in the area. I only use my thumb and middle finger with my elbow turned out towards the end of the saw with most of my hand resting on top of the fence. I do it out of necessity not invention but its actually much safer and was noticed by a union instructor 30 years ago and was added to the curriculum. A few of todays instructors have coined it Franks method claiming that the name came from saving your franks. It really came from my instructor that named my index finger Frank short for Frankenfinger. Frank has been reattached twice and the end reconstructed once all done on the same RAS. Quote
