Double Secret Blanket Chest Build
A little progress was made today on a few things that aren't very exciting.
First we leveled the pins and tails on the skirts.  Then we milled the cleats out of some scrap, attached them with glue and screws and flushed them up.
After that we worked on the moldings that will hide the transition between the skirt and case.  They will be simple 45* bevel moldings with slight chamfers at top and bottom.  We thought about using a cove profile but ultimately decided the bevels will give the chests a sleeker and more modern look.
I made a cradle for planing the moldings and we cleaned up the table saw marks with a smoother.
Tomorrow we plan to cut the cases to final height and work on the bottom panel joinery.
Back to real life on Thursday.  All work and no play makes Eric a dull boy.  I'm exhausted.
  • Replies 277
  • Views 44.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Okay peeps, let's wrap this one up.  We're done. We applied my typical protocol for most of my projects...four coats of ARS, three full-strength, the fourth thinned 50/50 with mineral spirits...
  • Well like we took this wood, and then we like cut it in to small pieces, and then we stacked on these  little sticks and left it there for like oh my gawd days!!!  Then we totally started cutting it s
  • Major milestone today: case dovetails are complete.  The Leigh is a total pain in the ass to set up, but I'll tell you what...it makes some very nice joints.  After a couple duh moments this mo
Posted Images
You're teaching him quickly how to do clean, detailed work. You use the smoother to knock down the dovetails? Didn't know if it would work very well on end grain.
I use a low-angle smoother to level my dovetails most of the time, but I set him up with the ROS for his.  No point in taking chances at this point.
Looking good man! Why are all the action shots of your buddy? Pass the camera to him, we want to see you in action!
I'm documenting the build so he can put together a photo book of sorts to give to her with the chest.  There's no need to have my pretty face in any of the shots.  I don't want y'all to get all depressed and jealous over my irresistible beauty and manliness.
Just got a LA smoother and set the micro at 35 which might be a little high for end grain. My LA jack is at 25 and I'll see how that does.
Nah, before I had my LAS I used my #4 for years.  It fights you a little more than the LA does but as long as you're sharp it works fine.  No question though that LA is better for end grain.  That's essentially the only thing I use my LA planes for.
well yeah and you don't want his bride knocking on your door.
Looking great man - good call making a little cradle for planing the moulding.  Good on you for showing him how to do things the right way.  Bottom panel just going to sit in a dado right?
Thanks man.  Yep, we'll rabbet the panels and fit them into grooves in the case.  We didn't quite get there today.  Grooves are done but not the rabbets.  If we get another two days in next week, we should be done with everything except the lids.  The faintest light at the end of the tunnel.  I'm pretty much sick of these damn boxes by now.
Wow I didn't see you had gotten the case joinery done. Looked back a few pages and found it. Those are going to look great.
  • 3 weeks later...
We had a few hours this morning so we made a little progress.  Started the day by cutting the rabbets in the bottom panels.
Test fit...
Dry assembly reveals no issues...
So...deep breath and for real this time...
And one case is glued up.  This is one time when having a helper came in real handy...so many joints to get glue on and these big parts are a bear to move around.
We'll get mine glued up later.  Don't really have the space or enough clamps to do both at the same time.
We used Mike's softwood caul method and so far it seems so good.  We'll find out soon enough.
Your box is a lot bigger but you should be fine as long as you waxed them. Do you find your Bowclamps very useful other than right now?
I forgot to wax them but they're covered with packing tape so they should be okay.
I find the Bowclamps useful when they're useful.  I use them occasionally but not often.  But when you need a cambered caul, only a cambered caul will do. :)
On 2/20/2016 at 9:19 PM, K Cooper said:
Pretty cool. Thanks.
next question... Shouldn't all cauls be cambered?
Not necessarily, Coop. I would use a cambered caul when I wanted clamping pressure in the middle where my clamps won't reach, but if I'm gluing up a panel and I want to keep the thing flat I use flat cauls. Like this:
http://IMG_1135_zpsuzfyuyq2.jpg
It's probably unnecessary if my boards are jointed correctly, but it helps make certain I'm not (over) clamping a crown or dish into my panel. With pipe clamps I thinks it's doubly important, because those things don't apply even pressure like a parallel clamp.
