Double Secret Blanket Chest Build
I used those Rockler hinges on the toy chest build. I had milled the hinge board a little less than 3/4" resulting in the torsion hinges having a slight gap. This caused the fixed part of the hinges to move slightly when the lid was opened. I wasn't too happy with that. So I fixed it by glueing some thin veneer shims onto the inside of the chest to make up full 3/4" thickness. The shims were sized so they are hidden when the hinges are put into position.
  • Replies 277
  • Views 44.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Okay peeps, let's wrap this one up.  We're done. We applied my typical protocol for most of my projects...four coats of ARS, three full-strength, the fourth thinned 50/50 with mineral spirits...
  • Well like we took this wood, and then we like cut it in to small pieces, and then we stacked on these  little sticks and left it there for like oh my gawd days!!!  Then we totally started cutting it s
  • Major milestone today: case dovetails are complete.  The Leigh is a total pain in the ass to set up, but I'll tell you what...it makes some very nice joints.  After a couple duh moments this mo
Posted Images
A little progress made yesterday.  We finished the skirt profile templates and got to bandsawing real wood...
Then got to routing...
Then cleaned up the corners the old fashioned way...
Crispy...
Colony...
Skirt glue-up today...if we can get the temp up in this igloo...
Skirts look great!  Nice job on the profiles.  Traditional and beautiful.
Very nice - what did you use to layout the skirt profile templates initially? Did you print out a template or draw it out freehand?
I tinkered around with French curves until it looked right.  Fairly simple profile...
My french curves (and drawing bow) definitely rank among the highest usefulness to cost ratio in my shop.  Couldn't imagine life without them.
Skirts glued up...
Custom cauls...
Not looking forward to the custom cauls we'll need to make for the cases. <_<
Joe goes out of town next week so here we go with another lengthy break...
Nice caul! I've wondered if pink insulation with wax on it would work for dovetail and box joints? You don't need a lot of clamping pressure and they'll conform to proud joints. I'll have to try it sometime.
Attention to detail like that pays off!  Nice job!
Looking good and great journal. Like a comic book, lots of pics and few words.
You're using epoxy it looks like? Looking great! I can relate to the igloo. Down to 32* here tonight!
Wow 32 farenheit, i feel terrible for you.....[emoji12]
Thanks bud, been out in this crap covering tomato plants. It's a bitch!
Eh, maybe.  I think the property that allows it to conform to the proud joints may make it ineffective to close up a stubborn gap.  It would be an interesting experiment though...you should try it and report back. :D
I used up all my words in the first post.  Plus I've been super busy so no time to blather on anyway.
Yep epoxy.  I've pretty much gone to epoxy full time for every dovetail glue-up.  Dovetails and Titebond is stress I just don't need in my life.
It's been freezing here all week.  We cranked the heaters and got the shop almost to 60* and went to work.  The epoxy flowed like snot but I liked the long open time and it cured up fine...skirts are already out of clamps.
I hope this crap passes quickly for you guys.
17 minutes ago, Mike. said:
its been around 0 farhenheit here most mornings.   32 is balmy!
Hasn't been quite that cold lately but we've only been above freezing 2 or 3 days since before Thanksgiving!
looks great eric, heirlooms in the making for sure. i'm going to have to try some of that epoxy, tired of the short open time of TB2 on big glue ups. refresh my memory will ya, west system epoxy? thanks
Yeah WS with 205 hardener.  I'm gonna get some 206 as well for even more open time.  Leaving stuff in clamps for a full 24 hours is a small price to pay for the huge advantage of the long open times.  The 205 has plenty of open time if you pour it out thin on a flat surface....but its pot life is only like ten minutes...it'll cook itself pretty quick in a Dixie cup.
Looking good E, although all I've seen is your buddies work... :)
Are you kidding? This has been such a mild winter in the mid-west. It's 26 in January. That's pretty ok in my book. It's when you get a solid month of 0 and below and some days hit -20 that you start packing your house up and looking for a job down south.
You know my policy. :D
5 hours ago, Mike. said:
I use one of these for epoxy.  It is wide enough that you get good open time.  I just reuse the same cup over and over.  I let the left over epoxy cure in the bottom and then use the same cap next time around.
http://www.amazon.com/Custom-Paint-Mixing-Plastic-Measuring/dp/B0023THLMG
After we have parties here we'll sometimes have those "good" paper plates...you know, they're a little thicker and kind of waxy-coated.  The smaller ones are great for this.  They get used up around the house and then I can't find any....I need to locate a big pile of cheap ones to keep in the shop.  They have to be cheaper than those cups...as useful as I'm sure they are.
So I wasn't brave enough to use pink insulation but I just tried alder with paste wax and it worked great. Alder is soft enough to dent under clamping pressure. Pine probably would have been better but I didn't have any in the shop.
2729541F-34C9-4BE7-B79C-33064036ED71_zps
26E5D3C3-F59D-4955-AD90-64BA1A5215A0_zps
Eh, maybe.  I think the property that allows it to conform to the proud joints may make it ineffective to close up a stubborn gap.  It would be an interesting experiment though...you should try it and report back. [emoji3]
I now have a reason to not chuck my aspen cut offs 1aed59038e93b07cf18a62cbe50e24f9.jpg
