I would vote # 2 or 9.  However what if you just left a 1/4 inch border and then took out the middle like an 1/8 of an inch.
This is really looking impressive Dave as you start putting it all together! ??
I think just a relief carving in the area inside the penciled area, similiar to the aprons, and a fleur de lis on all four sides will keep it simple, and allow you to take in the great job you've done on the legs.
Thanks for all the feedback. This is really terrific!
It is fun to hear the different opinions.
I think you're both saying leave the background blank. That's kind of what Eric said too. I'm very seriously considering just that. It would look good and not detract from what is already going on. No need for gratuitous ornamentation just because I'm looking to try a bunch of different forms of carving.
The thing is...I can always carve something in there and if I change my mind I can make it go away.
I think I'm going to try carving out a few more options in some scrap and see how it goes.
Hate to keep running you in circles, Dave, but I think something acanthus would be more appropriate for that area, since it would match the rest of the carvings.  Is there a reason you don't want it?
No reason at all. I just haven't come across anything that has caught my eye. Early on I was thinking of some kind of leaf-like scroll in mirror images on each side.
I'm still drawing patterns in my little boxes. I'll try out some leafy something and see what that looks like.
47 minutes ago, K Cooper said:
#1- ?
#2- not so much
#1 is on the aprons, a done deal.
#2 is another test piece. Just wanted you to know I'm still working at it. Work has been an intrusion these last few days.
I wanted to put up an update before I take off to the desert for a week.
I'm still working on some of the details, drawing more options:
http://IMG_1863_zpsiofzyrbh.jpg
http://IMG_1864_zps2ccryzzk.jpg
And seeing what some might look like:
http://IMG_1860_zpsg4ngegc6.jpg
Working on the overall look of the case:
http://IMG_1862_zpsf2ez8afq.jpg
And working on milling up some stock. I want to use the same stock that was used on the legs throughout the case, so although it may be somewhat wasteful, I'm going to mill down some 8/4" stock to get the case parts, doors, drawers, etc...
Here is how I true up an edge. After hitting some of the high spots with a jack plane I double stick a straightedge to the rough stuff and run that through the TS.
http://IMG_1861_zpsiadc8ukv.jpg
That gives me an edge that is straight enough to run up against the fence.
  • 1 month later...
So I screwed together a mock-up cabinet out of pine to try out my ideas for the Thing. As I go along I'll continue to use the pine box to try out variations.
First I worked on proportion. Tried this:
http://IMG_1880_zpsntkudy48.jpg
I liked it better after I cut it a little shorter:
http://IMG_1882_zpslkbsvic8.jpg
Then corner detail options. I had originally thought of some reeding.
http://IMG_1897_zps1ixs12sh.jpg
But I wasn't all that jazzed with it so I tried some twist:
http://IMG_1896_zpsma9xctsm.jpg
Then some plain ol' column with laurel leaves, which I'm kind of liking:
http://IMG_1895_zpsysmyxm8n.jpg
Just now, wtnhighlander said:
Still hand-tooling this, Dave? Those dadoes look extremely crisp and clean!
No way, Ross! I did those dadoes with the table saw and stop blocks. They're stopped dadoes but it doesn't really show in the photo. I will square off the ends and clean up any unevenness in the bottoms of the dadoes with chisels(my router plane is too wide to fit in a 1/4" dado).
All along I've had the philosophy that if it can be done with a machine then that's how I'll do it. I'm predominantly a power tool user who augments some operations and fine-tunes things with hand tools. Without doubt, carving is hand tool work but if I can hog out some material with a router, grinder, dado stack, or whatever, then I'm all for it.
