A bar cabinet.
Here's my latest project, finally complete. Design is my own, but is similar in format to many commercially available cabinets. Construction is 3/4" flat cut white oak plywood. Trim and corner treatments are also white oak. To make those plywood corner joints more robust, I glued in a 5mm square piece of solid oak & then chamfered the corner. For the most part it blends in fairly well with the plywood.
The detail on the left hand door is a goof that I turned into a happy feature. Somehow, I cut the door panel too narrow and didn't have enough plywood left to cut a new one. So I cut and carved the maple piece and glued it between the two plywood pieces. I'm pretty thrilled with the way it turned out. It's a nice point of interest visually and has a very tactile feel to it. That was the first time I've tried carving like that and it was a lot of fun to do.
Hardware and interior lighting are from Lee Valley. The power for the door lighting is cunningly conducted through the piano hinges, which are cut into two lengths for each side with enough of a gap to insulate them from each other. No loose wires dangling from door to carcass.
That has to be one of the best saves I have ever seen.  The whole project is outstanding.  Nice work.
I agree with the others, love the joint, love the maple detail (that was very clever), and the cat in the photo is cake icing.
How much juice is passing through the hinges to power the door lights?  Aren't they exposed?
Thanks for all the kind comments. Power is just a few watts of 12V DC. The hinges are painted.
That is really neat looking! Apparently you keep the catnip in there as well?
Nice save to say the least!
Beautiful project. The mistake turned into a feature is a great idea and the results are awesome. I like that the texture somewhat reflects the oak pores. The idea to run the electricity through the hinges is an interesting trick. Someday that is going to cause someone to stare at the door's for a long time trying to figure out how you power the door lights.
That thing is awesome! I wish that I had that much imagination and the skills to make it a reality.
I'm stealing that edge detail on your plywood.  Did you chamfer that corner by hand or use a router or table saw?
Great looking piece!
Thanks. I used a block plane on the corners.
Awesome build!! Love the design and the corner detail is stored in my memory bank now :D
  • 6 months later...
