Popular Post pkinneb Posted December 22, 2018 Popular Post Report Posted December 22, 2018 Not really fine woodworking but I needed to kick out five shop made gifts and with limited time I decided to make this cheese and cracker tray out of Woodsmith. First up was to breakdown some cherry boards. My chop saw is in the basement for that project so I used my plunge saw to do the work. Next up a quick jig to set up the TS to cut the coves for the tray handles I needed a 2" wide cove so I set the jig to 2" and then used blue tape to mark the front and the back of the blade where it enters/exist the cut Once I had that done I could set up the fences for both sides of the piece. I was having trouble figuring out how to get a clamp on the far end when I remembered Chestnut's tip from a few days ago handscrews worked great, thanks Drew!! Then set the blade to take about an 1/8" for the first few cuts and further on 1/6" as the cut gets wider Then its just push through flip push through rinse and repeat...forget about dust collection this makes a really big mess! ...but does a nice job fairly quickly, 5 sets Next I marked off for the 1/4" dowels that will pin the handles to the tray sides Then I drilled 1/4" holes through all the sides for all the trays. Once that was done they were ready to glue up Warning the glue up kinda sucks...made a mess of the first one getting glue in the cracker tray but after that I came up with a process that worked much better. I would dry fit one end then glue the other end and finally go back and glue the first. The tray sides and handles are cut at a 30 degree angle so you have to clamp from top to bottom to keep them aligned Next up I needed to make a bunch of 1/4" cherry dowel stock so after cutting some 3/8" square stock I got out my Elkhead tools TS dowel jig and set it up. Then I hand fed each piece in to make a small dowel I can chuck in a cordless drill Then I ran one through and gave it a test fit Once I had the fit I ran the rest through Next up was to drill the handles. I used the holes drilled in the sides for a guide and then made a wood depth stop Cut the dowels to length Glued them in I cleaned up the over hang with a sharp flush saw, so sharp I cut myself Then I cut the waste away at the TS to reveal the handle Once that was done I cleaned up the coves first at the TS then with sand paper on a 2" piece of conduit, cut a curve on the handle ends, and made some small cutting boards for the centers. After some edge finishing and final sanding they will be ready for finish and bows with two days to spare I also knocked out another lamp like the ones I did last year I'll post up some final shots after the finish is applied. 13 Quote
Coop Posted December 22, 2018 Report Posted December 22, 2018 Those are slick as can be. Great ideas. Good detail. Thanks for sharing Quote
Steve B Anderson Posted December 22, 2018 Report Posted December 22, 2018 1 hour ago, pkinneb said: Not really fine woodworking but I needed to kick out five shop made gifts and with limited time I decided to make this cheese and cracker tray out of Woodsmith. First up was to breakdown some cherry boards. My chop saw is in the basement for that project so I used my plunge saw to do the work. Next up a quick jig to set up the TS to cut the coves for the tray handles I needed a 2" wide cove so I set the jig to 2" and then used blue tape to mark the front and the back of the blade where it enters/exist the cut Once I had that done I could set up the fences for both sides of the piece. I was having trouble figuring out how to get a clamp on the far end when I remembered Chestnut's tip from a few days ago handscrews worked great, thanks Drew!! Then set the blade to take about an 1/8" for the first few cuts and further on 1/6" as the cut gets wider Then its just push through flip push through rinse and repeat...forget about dust collection this makes a really big mess! ...but does a nice job fairly quickly, 5 sets Next I marked off for the 1/4" dowels that will pin the handles to the tray sides Then I drilled 1/4" holes through all the sides for all the trays. Once that was done they were ready to glue up Warning the glue up kinda sucks...made a mess of the first one getting glue in the cracker tray but after that I came up with a process that worked much better. I would dry fit one end then glue the other end and finally go back and glue the first. The tray sides and handles are cut at a 30 degree angle so you have to clamp from top to bottom to keep them aligned Next up I needed to make a bunch of 1/4" cherry dowel stock so after cutting some 3/8" square stock I got out my Elkhead tools TS dowel jig and set it up. Then I hand fed each piece in to make a small dowel I can chuck in a cordless drill Then I ran one through and gave it a test fit Once I had the fit I ran the rest through Next up was to drill the handles. I used the holes drilled in the sides for a guide and then made a wood depth stop Cut the dowels to length Glued them in I cleaned up the over hang with a sharp flush saw, so sharp I cut myself Then I cut the waste away at the TS to reveal the handle Once that was done I cleaned up the coves first at the TS then with sand paper on a 2" piece of conduit, cut a curve on the handle ends, and made some small cutting boards for the centers. After some edge finishing and final sanding they will be ready for finish and bows with two days to spare I also knocked out another lamp like the ones I did last year I'll post up some final shots after the finish is applied. You should try to make the lamp shades to match the base glass. I’ve been investigating making some Mission lamps and those shades are selling for $200 to $500. 1 Quote
wdwerker Posted December 22, 2018 Report Posted December 22, 2018 That's quite involved to " kick out " some gifts ! Don't forget to sign & date them . 1 Quote
Tom King Posted December 22, 2018 Report Posted December 22, 2018 Looks like some pretty fine woodworking to me, as well as a fine job of documenting the process! 2 Quote
gee-dub Posted December 22, 2018 Report Posted December 22, 2018 Great tutorial on a production run for the holidays . Thanks for sharing that. 1 Quote
wtnhighlander Posted December 22, 2018 Report Posted December 22, 2018 Hey, those look great! Are the CB centers glued into the trays, or removable? 1 Quote
Isaac Posted December 22, 2018 Report Posted December 22, 2018 They look great. Please share a shot after you've applied the finish. 1 Quote
pkinneb Posted December 22, 2018 Author Report Posted December 22, 2018 1 hour ago, wtnhighlander said: Hey, those look great! Are the CB centers glued into the trays, or removable? Thanks! They are removable 1 Quote
Chet Posted December 22, 2018 Report Posted December 22, 2018 Those look great and should be well received. Thanks for sharing the process. 1 Quote
Bankstick Posted December 22, 2018 Report Posted December 22, 2018 Don't know where to start. Thanks for the photos of the steps for the project. You put a lot of time in the jigs to do the operations as well as a lot of time and thought into the trays themselves. I would like to see something similar about the lamp. 1 Quote
Chestnut Posted December 22, 2018 Report Posted December 22, 2018 Nice work. I love those lamps. 1 Quote
mat60 Posted December 22, 2018 Report Posted December 22, 2018 You do some really nice work. Best looking lamps I have seen. 1 Quote
Mick S Posted December 22, 2018 Report Posted December 22, 2018 Nice work, Paul. Especially under the gun. I've been helping friends get their last minute projects finished and am now going to have to make apologies for being late with mine. Come to think of it, that's what I did last year! 1 1 Quote
pkinneb Posted December 23, 2018 Author Report Posted December 23, 2018 6 hours ago, Bankstick said: Don't know where to start. Thanks for the photos of the steps for the project. You put a lot of time in the jigs to do the operations as well as a lot of time and thought into the trays themselves. I would like to see something similar about the lamp. Here is the build thread on the lamps 4 hours ago, Chestnut said: Nice work. I love those lamps. Thanks for the clamp tip it came in handy Quote
Popular Post pkinneb Posted December 23, 2018 Author Popular Post Report Posted December 23, 2018 On 12/21/2018 at 10:00 PM, Steve B Anderson said: You should try to make the lamp shades to match the base glass. I’ve been investigating making some Mission lamps and those shades are selling for $200 to $500. I have made a couple smaller shades like this one Next year I will be making a Oak and stained glass pool table light which should be challenging This pic is for Steve I sprayed the trays ...and used mineral oil for the cutting boards. Three coats of just oil and then a final coat of 4/1 mineral oil and beez wax. Ran short on cutting board blanks but since I only needed four gifts I will make the 5th later. I always try to make an extra when doing this stuff last minute just in case, but knock on wood to date I haven't had to use one. Having said that the minute I made only what I needed well you know how that would go LOL here's the first two ready for delivery and not a moment too soon. Heading to the airport to pick up our daughter and then off to deliver the first one to my aunt. Have a great holiday everyone!! 6 Quote
RichardA Posted December 23, 2018 Report Posted December 23, 2018 Beautifully done. Excellent craftsmanship. 1 Quote
Steve B Anderson Posted December 23, 2018 Report Posted December 23, 2018 Very impressive, looking forward to the pool table light journal. 1 Quote
Bankstick Posted December 23, 2018 Report Posted December 23, 2018 Used to sell lighting- Tiffany style shades are outstanding. Original lamps bring a king's ransom. 1 Quote
curlyoak Posted December 23, 2018 Report Posted December 23, 2018 It was a pleasure to watch this process unfold. Execution and design could not be better. Thank you! 1 Quote
Mick S Posted December 25, 2018 Report Posted December 25, 2018 This is one of those threads that reminds me of the "how do you save a thread for future reference?" from a while back. Definitely tagging this one for next October with a reminder! 1 Quote
SirNot Posted January 10, 2019 Report Posted January 10, 2019 This is one of my favorite projects from The Woodsmith's Shop. You executed them beautifully. It's on my list for next Christmas! Quote
pkinneb Posted January 10, 2019 Author Report Posted January 10, 2019 2 hours ago, SirNot said: This is one of my favorite projects from The Woodsmith's Shop. You executed them beautifully. It's on my list for next Christmas! Thank you! I have actually made quite a few of their projects over the years especially for xmas gifts with good response from those who received them. I'm thinking next year maybe bowls off the lathe. It seems like we have more folks on here sharing turning tips which is cool Quote
